Penguin_Rob's avatar
Penguin_Rob
Advice on towing with Yukon Denali
Hey folks, I recently bought a 2017 Yukon Denali, and plan on getting a TT around 23-25 feet. I would expect that it won't exceed 5,000 lbs. or so. My questions are: 1. Should I get a weight distribution hitch or just rely on the self leveler. 2. Is there a reason GM advises on not using the adaptive cruise control while towing? Thanks in advance for any advice or experience you can share!
  • My TV is similar and TT is 5,100 pounds wet/loaded. YES on the weight distribution hitch. I believe I stop better with the weight shifted back up front. And twice I've had to stop fast for left turners. I do use cruise in dry conditions despite GM's recommendations. I'm not an expert but have had no problems and like having my speed monitored by a computer. Full control, Jerem, without watching speed.
  • Definitely get the WDH, can't hurt anything and can only help - just check the manual, as mine specifically says I can't use any hitch devices (weird land rover thing).
    Adaptive cruise probably has a couple issues - one of which is the fact that it (normally) brakes the vehicle if required. Using an electronic brake controller, I'm not sure if it'll activate the trailer brakes. Actually yours almost certainly has an integrated brake control system, but I'm still iffy on it allowing adaptive-cruise to modulate trailer brakes.
    Trans shifting and hunting is probably also a big problem. On mine I can use command shift to lock in a certain gear and still use cruise control, but on a 10hr trip I only used it for a couple minutes. Like the last poster said, I feel way more comfortable being in control. Plus it's always good to have your foot near the pedals. Also almost any change in incline or speed required a gear change and totally different throttle, so I really couldn't let cruise do much of anything in command shift mode anyways. In auto w/ cruise it would almost certainly downshift one extra gear more than it needed to EVERY time there;s a speed change, which gets old really fast.
    Also you might want to check the break-in periods and requirements in your manual since it's so new. Even though that's not a super large trailer, it'll definitely be the first work your SUV has ever had to do. :)
  • Hello,
    Congrats on the new Truck!
    Yes, you will need a weight distribution hitch. The self leveling system will level out the rear end but does nothing to help restore the lost weight off of the front tires.
    Also, as far as the adaptive cruise control. When you tow you have a vehicle that pivots in the middle, I can see how the adaptive cruise control could cause issues with this, possible causing a sway event or even a loss of control. I would definitely stay away from adaptive cruise control or any other auto pilot feature, heck, cruise control in my vehicle is not used while towing. I want to be 100% in control all the time.
    Thanks!
    Jeremiah
