NorseNW's avatar
NorseNW
AF 1150 trim strip fix?
So completely new to the truck camper stuff. We have about a year under our belt now and loving it. Our setup is a 2015 Chevy 3500 dually diesel and AF 1150.
A few months ago I noticed a wavy spot in the diamond plate on the side wall of the basement area on the slide side. Hopefully the pictures explain it better than I can. It appears the diamond plate got pulled down or bumped into something causing it to come down below the trim piece and get stuck outside the trim piece. Aesthetically I could care less. The problem I see is this now has a nice open spot for water, snow, dirt, critters, etc to get in. I would like to get it sealed back up.
I contacted my local dealer and they said it looked like we ran it into something. My wife disagrees with them but I'm thinking we did it. On one of our first couple trips we decided to take the camper off to go explore some places. Not knowing any better we left the slide out put the jacks down and off she came. When it came off the truck it moved toward the slide side due to the weight. My guess is this piece rubbed up against the truck wheel well in the bed of the truck. That motion would pull down and away causing the issue I now have.
Local dealer said to bring it in and they will take a look at it which is great and they have been nothing but good to us through the purchase process. Here's where I start looking for a better option. They want $100 just to take a look at it. I get it that's pretty standard wage for getting stuff worked on but I'm a handy guy and do a lot myself. Plus it's a 2 hour drive to Apache and all the sudden I'm in this for an entire day maybe more to get this fixed.
Sooooo - Would someone be able to tell me how this trim strip is attached before I start reefing on it? It appears from my antics of trying to pull down on the diamond plate piece to get it to slide back under that the trim strip is just shiny plastic.
I'm guessing just pulling that trim strip off and putting a new one is about the only way to go. I've also thought of make two cuts on either side of the bulge and taking just that piece of finish strip of and replace it with something else.
Any suggestions are greatly appreciated
[img][/img]
  • Yes it certainly does not need to pretty for me. Just functional and not allowing stuff into the voids. I've gotten away from the pretty stuff and more into functional as I get older. Kind of like me - less attractive but more functional than I used to be........ That's what my daily mirror affirmations are anyway!
    I may just start pulling stuff off after our trip this weekend and see how functional I can make it. The worst that can happen is I screw it up worse and still need to take it back in. Seems like the Northwood gent was mainly concerned about getting it sealed back up which is where I'm thinking as well.
  • I don't think you have to replace plating, but you will have to remove it and clean off the adhesive. I do not think it is welded anywhere but do not know how the ends are held in place.
    You could skip removal and use a wooden block to straighten the plating and clamp it down after filling the voids with adhesive, but it will not be a perfect fix even if it is functional.
  • Super Dave - yes that is the correct piece. From what I can see it's just a plastic trim strip. There is a space between the two pieces of diamond plate there. I'm not so concerned about the plastic trim strip it's the diamond plate on the bottom side that is bowed out a bit leaving a gap for water and junk to get in.
    Unfortunately I think Bedlam may be correct. To properly do it that whole piece may need to come off. It just doesn't seem like there is any adhesive on the back side. But I'm not sure how to get the diamond plate to lay flat again.
    Here is the response from Northwood Mfg that leads me to believe Bedlam is on the right track - "if you didn't want to replace the diamondplate, i would find a flat molding and install it there . and be sure to seal it with geocell. staple the diamondplate on both sides to make it lay flat. seal it and mold it. then seal the molding with geocell"
    I don't think I have the know how or tools to replace that whole sheet of diamond plate. I used to weld aluminum but that was many moons ago and don't have the equipment anymore
  • It is unclear to me what purpose this piece serves? Also not 100% sure what I'm seeing in the picture. I'm assuming you are talking about the piece that runs a couple of inches from the top of the diamond plate and the full length of the floor?
  • Is it still under warranty? If so have Apache fix it, doing a DIY would void any future warranty repairs.
  • If you see abrasions on the diamond plate where it was in contact with the truck bed, I would agree with the dealer that you pulled it off when offloading. If there is no sign the the diamond plate is scuffed, it may have been poor application of adhesive from the factory. My AF811 has a couple of surface scratches where it came too close to my tailgate opening, but I have had no separations or dents in the diamond plate.
    To fix this properly would require removing the diamond plate and old adhesive before cleaning and applying new adhesive.
