EEEO
Apr 23, 2015Explorer
AF 811 mods & upgrades, solar, satellite, etc.
My wife and I upgraded from an old '99 Winnebago TC (our first TC) last year. We deliberated for some time as to what we should do, since a Class B seemed like a good option, but we happened across a good deal on a 2013 AF 811, so we decided to pull the trigger. I'm starting this thread to document the upgrades I plan to do, and solicit input and advice from anyone who might be willing to share. I'm planning on pulling it out of storage next week, and get after some of these upgrades.
I'm planning the following:
1: Installation of solar panels. I've ordered a 200 watt kit from Windynation. Yes, I've read the RV Charging Puzzle. My intent is to adjust the charge controller and see how things shake out. I can always change things around or replace the controller if need be. My plan was to place the panels above the bed running N-S on either side of the skylight as I don't think there are many other places they would fit. My AF is pre-wired for solar (no idea if the wire they used is adequate yet), and there is a sticker on the wall behind the sink stating that the wiring is in that location. This kit comes with a temperature sensor as well. Has anyone installed a similar system? I'm guessing that they didn't pre-wire for a temp sensor, so I'll have to determine how to best route that to the battery compartment.
2: Installation of a Winegard Carryout G2 satellite dish.
This one poses a few problems. The largest of which is where to locate the receiver. I can put it inside the cabinet behind the TV, but I don't want to have to open the door to change channels. Any ideas on receiver placement? I've considered modifying the door to accommodate a screen or something, and also seeing if there is a way to mount it between the top cabinet and the bottom.
3: Adding an inverted outlet somewhere in the kitchen area.
4: Doing this basement fan mod that I'm apparently not the first one to think of!
5: Completing some sound mitigation work on the Onan LP generator. I can't seem to find it now, but I ran across a thread a while back where someone had installed some sound-deadening material inside the generator compartment. Any ideas where he got that stuff from? He also added a resonator or some type of 2nd muffler. I'm not sure if I have the room to do that or not. I'm guessing I'd have to remove most of the exhaust pipe to accommodate it so it wouldn't stick a foot out of the back of the camper.
6: Not exactly a mod to the AF, but I'd like to try and convert this coleman grill I already own to use the on-board propane on my AF. I have the quick coupler on the back, but I need to ditch the regulator that came with the grill and replace it with a simple control/metering valve along with the appropriate connector and hose assembly to connect it to the AF. The rub is that they don't make a conversion kit for it, so it may not be all that easy to do. Why try, why not just buy a new grill you ask? Well this grill fits nicely in the storage compartment under the dinette, and I haven't found one that uses on board propane that would fit in there. If I could find a grill that would pack somewhere easily I would gladly buy a new grill, but I'm not hopeful.
7: Replace all incandescent lamps with LED's. If anyone has any suggestions in this department, my ears are open. They need to be dimmable, since some of the lights are on dimmers in the AF. I had bought some LED lamps off Amazon for our last TC, but several of them failed after a short time or never worked in the first place.
If I had it here I would have taken some photos to add to this post, but I'll have to get to that once I get it out of storage.
Cheers!
Cheers!
