2016 Arctic Fox 990
I've had it for just apx 2.5 yrs now, full timer 90% boondocking.
Rollers:
The only real problem was the rollers underneath the slide keep popping out. While I haven't really seen anyone else have those problems, I did. They say to lube the tracks and that would lube the rollers but didn't learn that till after the fact. Dealer put them back in the first time, then fell out again, haven't been back and other dealers won't even talk to you during their busy months May-Oct.. Slide still works, grunts and groans and I do lube the outside tracks, but would like to not have this issue.
Fridge:
It works ok, running on propane. Ice Cream is a little hard to keep hard cold as it will soften I guess when it's defrosting. Keeps other stuff, meats etc, frozen. I'll check out the above referenced fans or whatever it was..
Propane:
With the 2 tanks, one tank usually last 8-10 days or so weather dependent, it's not a problem. I turn one off (it has an auto switch) so I will KNOW when one is empty. It does require me to go out and switch it over, but it's something I choose to do to keep track. I also carry an extra 30lb tank, typically for BBQ but also as a backup which has been used several times as I forgot to turn off the other tank and it auto switched. Just my fault for not paying attention.
Black/Gray Water Tanks:
I figure 7-days I plan on a "Dump N Fill". Dump Tank level gauges stopped working correctly after about 3 months or so, always show FULL, tried the various cleaning techniques, next level will be a rod spray to clean off the sensors on the Black tank, not sure how to do the Gray one.
Water tank is my indication it's time to go in for the Dump n Fills.. Gray water tank has recently been backing up at about the 7-day period. Suspect it needs a good cleaning, tried the "Happy Camper" and soaps to no avail.
Insulation:
Coldest was down to 16F night, furnace handled it fine, no discomfort, will obviously use more propane. Currently, today, it dropped down to 26F and no problem. Suggest you look at the Mattress heating pads, they are great.. and plan on a new mattress in a year or so.
Generator:
I have the options Onan w/Propane. It works well, but loud and use propane. I also have the Honda 2000i which I use constantly, it's quieter and not a problem to use, just keep it chained up as they have a bad habit of walking away in certain areas. The Onan is a back up so-to-speak, apx 25 hrs on it since purchased. I run it apx 1 hr every month or 2 but be aware, you'll need to run it before the batteries are too low or it won't crank it over, heheh, don't ask me how I know that. No big deal, just started truck and the Onan started right up. Having it might be overkill if you have a Honda, but as they say, One is none, two is one etc...
Solar:
As a side note, have a "Solar Specialist" do solar if you're going in that direction. Plan ahead for future use on panel location and wiring and batteries. I believe you have the option for 12v or 6v, 6v is better apparently.
Steps:
I had been using the Giant Ladder step ladder but eventually got the Torklift Stow go which are perfect. No fuss, no muss as they say and great for the Wally World (Walmarts) market resupply.
Other than the above, the camper is terrific, solid, insulated and not afraid to take it anywhere. As long as the Truck can carry it properly, I ended up with a 5500 and it's not a problem in the x-winds etc on the highways..
I'd get one again if and when the need arises...
Well, I've rambled on enough, it's a good camper.
Hope that helps...
