broncobran68's avatar
broncobran68
AF 992-no 12v in slideout-furnace/fridge/light
I’m hoping someone can point me in the right direction here. I’ve lost all 12v power in my slide out room. The slide itself works, but the fridge, furnace, and overhead light are all dead. All other 12v systems seem to work fine. All the fuses are good.
Sounds to me like a grounding issue. Does anyone know if these items share a common ground within the slide? If not is there a bus bar somewhere that I can check?
  • broncobran68 wrote:
    You are correct! I reconnected a nine pin connector under the center of the slide from inside the camper. A pain to reach, but all good now.
    Good to know. I had no idea there was a connector under the slide. Makes me curious to know if my 811 has something similar.
    I've messed with the wiring bundle and routed new wires along side it but never noticed a connector under there.
  • You are correct! I reconnected a nine pin connector under the center of the slide from inside the camper. A pain to reach, but all good now.
  • There is an umbilical under the slide, move it out about foot and look up under there.
