Me Again wrote:
Get rid of the puck bottle and extended the breather hose down below the engine slightly. You will most likely find that you rad looks like the one pictured earlier.
Spray it with Simple Green and hose and leaf blower it from the front to wash it clean. It is a really messy job. All the **** is gong to end up on the front of the engine and you then have clean it also.
Chris
Yes, my slobber tube is "vented to the atmosphere" hangs down some but not enough. Makes a mess on trans pan. Going to add about 4 inch.
Regular Simple green or the big buck stuff for alum and aircraft?
For coolant mixture, I use 50/50 premixed either fleet gaurd or Cummins
