...with the the two 12 vdc Interstate batteries -snip- I had 88 ampere/hours.
With the 2 6vdc batteries in series, it's offering 230 ampere/hours--- HUGE increase!
Hmmm... sounds to me like the Interstate rep' didn't do a particularly good job explaining real world battery capacity :(
With your two group 27 batteries in parallel you had a total capacity of ~176 Ah (@ 20hr rate). However, it is generally accepted that you should only discharge to 50% SOC, so that gives you ~88 useable Amp-hours. Two 6V AGM GC2 batteries in series have a (best case) capacity of ~220 A/h (@ 20hr rate), so that's 110 useable Ah.
Yes, 100Ah is more than 88Ah...
But without proper charging, you will get neither the rated capacity nor the desired service life from your expensive new AGM's.
gitpicker2009 wrote:
.. I was letting the coach, plugged into shore power, charge the batteries, and apparently that's not a good idea, as the "floating" charge point is too high.
This makes a strong case for you
not using AGM batteries. If you "boil off" electrolyte from an AGM it cannot be replaced.
As I asked previously; How do you intend to charge these new batteries??
There are some very good reasons to spend your hard-earned money on AGM batteries, but so far I haven't heard you mention any of them.
Cheers,
-Mark
