buc1980
Jan 19, 2022Explorer
AGM battery
I heard that a AGM battery is not recommend for 2017 Ford F350 because the alternator will charge them wrong and it short the life of the battery.Anybody know that?
JKJavelin wrote:valhalla360 wrote:
The real question is why bother for a starting battery.
The main advantage of AMG is they don't spill if you roll them over. Great on a boat or a stunt plane...not so much for a starting battery.
I would say the biggest reason is that they are maintenance free. A lot of people these days don't even know how to open the hood.
JK
time2roll wrote:
For superior cranking amps and slight advantage on voltage, additional freeze resistance, faster charging, zero maintenance AGM is a great choice at a premium price.
dodge guy wrote:
FLA batteries are the dinosaurs of the battery world! AGM and Gel batteries are the new and better batteries. No doubt LiFPo batteries are now the new way to go, but these for sure need the proper charging voltage, which is why you need a DC to DC converter to use them in the RV world so you don’t destroy them. I’m just starting to learn about them. But at $800-$900 each it will be along time before I consider one for my type of use.
When the MH house batteries are due I’ll be going with AGMs.
ScottG wrote:
Vehicles that come from the factory with AGM's have a slightly lower system voltage. That is the reason they are not a good retro-fit for normal systems. The higher voltage seems to shorten their lives.
buc1980 wrote:NO. I don't buy that.
dodge guy wrote:
An AGM is a much more stable battery, can be ran down a bit farther than FLA batteries. For these 2 reasons they are a better choice!
