S_Davis
Jun 11, 2020Explorer
One of the main things with air bags is you don’t want to unload your springs, if you do you your sway and bounce will increase. I did air bags on my 2013 2500HD with a 3000+lb commercial work cap and the ride was too bouncy and I had more sway, I ended up going with a set of 3500lb helper springs and then the bags were just used to level side to side. The problem with upping the springs is unloaded ride suffers so that might be a deal breaker for you, my truck has a load 95% of the time so I can deal with the harsh ride with the small amount it is unloaded. I did have 19.5 tires so that did contribute Some to the harsh unloaded ride.
