billtex
Jun 12, 2020Explorer II
silverbullet555 wrote:billtex wrote:
Had airbags, supersprings, and sway bar on last truck. Won’t do airbags again. There are better options, less hassle, more robust. With the tongue weight you are suggesting, I don’t think airbags are necessary.
FWIW; I question the weight of that TC also.
Visit the scales and then report back here. Guessing at your weights isn’t very helpful.
I'll get some weights.
What are the better options you are referring to?
My previous truck was same as yours. You don’t have upper over loads on that truck, but there are several options. Let’s see what you have for weights and then we can make suggestions.
You may not need anything!
What are you running for tires?
Edit; just read your OP again. So you have 4” sag. If you plan to tow the boat frequently with the TC on, SuperSprings may be the way to go. They will only engage when loaded and will significantly increase your spring rate.
I put SS after I had airbags. After that the bags were just along for the ride. The SS were carrying the load no problem.
But let’s not get too far ahead. Load up and hit the scales.
