silverbullet555
Jun 12, 2020Explorer
Kayteg1 wrote:
Front weight with TC are non-essentials, but I see you have only 500 lb spare weight on the rear.
600lb tongue with 2' extension will add 800-900lb.
Did you have food and beverages in the camper?
So even when you go with trailer extension to avoid stinger and lower the tongue by moving the boat back, there is no way you will not exceed axle rating.
Will you still stay within tire rating?
I need to get the trailer weighed so we are working with real numbers. Hopefully this weekend if the weather cooperates.
Food and beverage not included. If I load correctly, I should see the weight be forward of the axle. Not a solve, but still better than aft.
I will not exceed tire rating. They are 3750 per so I have nearly 2K lbs before the boat trailer goes on.
