silverbullet555
Jun 13, 2020Explorer
DWeikert wrote:
To the OP, may I also suggest better shocks. The OEM shocks on my truck were pathetic. I replaced them with KYB Monomax and that significantly reduced the rocking. Since you're planning to use the truck as a daily driver adjustable Ranchos may be a better choice for you.
PS: Another way to improve unloaded ride is to lower your tire pressure. You don't need 80 psi in the rears of an unloaded truck and that alone will take a lot of harshness out of the ride.
To be fair. I drive an 88 Suburban a lot which is stiff as hell.
Shocks are bilsteins so already upgraded somewhat. Lowering air pressure is also key in the off season.
