billtex
Jun 21, 2020Explorer II
silverbullet555 wrote:
Bringing this back up as I now have real weights for the boat.
Gross trailer weight 6100lbs
Tongue weight 480 lbs.
Truck with camper, 3/4 tank of fuel, me and 2 boys.
Front Axle 4400
Rear Axle 5580
GAWR
Front 4670
Rear 6084.
I'm right at limits for gawr with the boat hitched.
My understanding is tongue weight would lighten a bit if I extended the tongue which may not be good. The tongue weight right now is just at the lower end of recommended %.
Seems like overload springs, a super hitch and a super hitch truss extension are likely in my future. The 15" extra long ball mount is only rated to 6000 lbs.
Sounds good. A tire upgrade may be in your future.
I extended the tongue on one of our boat trailers. The extension allowed me to tow with the TC on and not use a hitch extension. So it was a bit of a trade off. I did need to crawl under the camper to engage/dis-engage the trailer which was a PIA.
You are correct about tongue weight; too lite and you may get some sway.
44,071 PostsLatest Activity: Aug 23, 2026
