trailerbikecamper wrote:
Is the total air on all four corners or just the back end of the TV? I have seen boh systems.
What is the benefit of going all four corners over just the back end?
I just have mine on the back at the moment and it will probably stay that way now (bought a new TV to spend money on LOL!).There are a couple benefits for all four corners that I can see personally.
1. Better ride and adjustment of that ride per conditions
2. If you off road much you can get better clearance
3. You can lower the clearance and also drag on the highway (MPG ?)
I can already tell I'm going to miss my air ride on the back of my new one and have not even towed the camper yet other than out of the driveway to get my hitch height set right. This has been the first time in a few years that I have had to use the slow power landing gear on my 5er. I always use my air suspension to level the 5er front to rear and hook and unhook from it. My unloaded ride with the air on the rear is great and when the truck has the 5er on it the ride is 100% better. If you go with the add on bags your ride will also be a lot better loaded but not or not as much unloaded.
Also with all air and my truck not having a rear sway bar I can plant my tires to get optimal traction on uneven ground. Backing long 5er's in small tight sites that have ditches around them and or across from them really makes this feature shine.
You can really set up an all air system to do a lot with valves and accumulators if you think about it and plan it out. I've thought about doing the front on my '05 and removing the sway bar and doing a test like on the frame twist test that GM did with the F350 and the 3500 Chevy. I believe I could keep all 4 tires planted on the ground with the front done. LOL!
