Absolutely 1000%
My first rig was 1994 CK2500. It was an old city work truck I got at auction.
It had a flatbed with an old heavy style lift gate on the back. I took it to a good welding shop and got some mods / fabs done to keep the gate and be able to tow a TT. I also added a 35 gallon gas tank in the center nose of the bed. (No jerry rigging. It was a transfer flow.)
And I added some gang boxes on each side.
I was dead on max spec all the way around from every which way you can measure it.
But I was a little heavy on the left. Bad enough to list and make me fight it while driving; which really does not take as much weight as you might think.
I also had a "pinch point" at the hitch. (If that's the term for when the hitch rides low and the rear sags so far it pulls up the nose making it hard to steer?) Between that lift gate and the tongue weight I had about 1500# behind the rear axle.
I added a set of airbags with a "manual" (non-digital) actuator system with a pressure gauge for each side. I had to set the left @90psi and the right @20psi to level her out.
I added a husky weight distribution hitch.
It road like an absolute dream for more than 10K miles until some gang banger attacked us on the highway and make it roll over.
