ticki2
Apr 18, 2016Explorer
230# is not enough tongue weight for a 9000+ trailer , that's less than 3 percent , 5 to 10 percent is recommended for boat trailers .It is probably the biggest contributor to the porpoising . A weight distributing hitch will help move some of the rear axle weight to the front . You are at or over most of your limits GVWR , GCWR , GRAWR . Air bags will lift the back of the truck but will not necessarily fix all the problems . Take a hard look at all the parameters before deciding on a direction .
