Kayteg1
Apr 21, 2016Explorer II
TN Sportsman wrote:
On a side note regarding air bags, I just found out that Torklift recommends running NO MORE than 30 lbs. in air bags if you have Stabilloads installed. Since I do, would 30 lbs. even be worth having in my situation, even if I could custom build a set? I'm thinking not. Timbrens may be my best option.
Airbags are rated for 5000 lb @ about 100 psi, meaning 30 psi should give you 1500lb lift.
Is that about the weight of your camper?
