TN_Sportsman
Apr 21, 2016Explorer
Kayteg1 wrote:
Airbags are rated for 5000 lb @ about 100 psi, meaning 30 psi should give you 1500lb lift. Is that about the weight of your camper?
Actually I'm right at 2000 lbs. loaded.:o I know, crazy for a pop-up.
Jim, what do you mean by "valving to slow rebound"? Do you mean the shocks are what stops, or softens the porposing effect?
