TN_Sportsman's avatar
TN_Sportsman
Air bags and cat scale shock
Hi all, it's been awhile since I have posted. We recently took our first spring trip this year to do some fishing. This was the first time I had hooked up the bass boat with my TC, and I noticed that it has a little more squat than I would like, even though my boat trailer tongue weight is only 220 lbs. My truck sits fairly level when unloaded to begin with, so the resulting squat is no real surprise even with the Stabiloads. I also noticed some porpoise when going across bumpy roads as well, which has got me thinking I need to install air bags to get me back to level, and increase handling. I can get a set of Air Lift bags for my truck for about $340. Any thoughts?
I knew that I was pushing my trucks limits, so I wanted to get weighed with a full load. My previous calculations had me right at GVWR (8600 lbs.), and 1000 lbs. under my rear axle rating (6000 lbs.). After being weighed with this setup I was 480 lbs. over GVWR, and 520 lbs. under my rear axle rating. The GVWR doesn't really bother me, but dang I didn't want to get that close to my rear axle rating! I know air bags don't increase your carrying capacities or ratings, but I am thinking they would help the handling and the ride.
I know I am going to get an array of opinion on here for my setup, but I was just wondering if any of you are operating within similar limits and your experiences doing so. This is our first TC and we really like it, but this pop-up is HEAVY!! I really don't want to get rid of it, but maybe we should have gotten the model without the toilet? :(
  • The internal bumpers don't contact until you are below the normal installed height of the bag. Empty you will be running above the normal installed height of the bag if they are installed correctly, so they won't be touching except on nasty bumps, just like the OEM stops. The bags replace the OEM bump stop in most applications, so it really shouldn't change your empty ride. Timbrens are just a great big rubber bump stop that always has to be pretty close to contact or it won't do any good.
    Always wondered about the quadrasteer truck - seems like it could be pretty neat in some situations.
  • WNYBob wrote:
    If you go with the air bags make sure that you get the ones with the internal bumper, then you will not have to worry about running them without air!
    Wouldn't the internal bumpers make the truck ride rough unloaded? Similar to Timbrens? That was the biggest complaint I heard with them.
    You don't mention anything about tires or shocks, I upgraded both and it made a world of difference.
    I am running Michelin M/S load range E, and my truck is equipped with the adjustable orange HD shocks from the factory, but I believe they may be Delphi?
  • If you go with the air bags make sure that you get the ones with the internal bumper, then you will not have to worry about running them without air!
