freetime58
Oct 22, 2019Explorer
Currently on my third GMC truck (in the last 12 years) with Firestone RideRite air bags with their Air Command compressor system on-board. The previous two trucks had digital gauges and a switch under dash to inflate/deflate the bags.......my current system has a wireless remote control used to inflate/deflate the bags. Love it!!! You can stand several yards away from your TV, eyeball the truck, inflate/deflate the bags using the remote until she sits level...........
Over the last 12 years the systems I have had preformed flawlessly, performed as they should......IMO, great product, no drill installation making them so easy to install yourself with just common hand/power tools.
Running empty with only 10 lbs in the bags so as to not damage them (recommended by manufacturer) with no effect on ride/handling, they have been up as high as 85 lbs depending on the situation but typically 30-55 lbs is the range I most often use, no matter they provide improved performance to ride, stability and handling............I never leave home with out them!!!!
44,056 PostsLatest Activity: Feb 28, 2026
