Colo_Native
Dec 05, 2015Explorer
Air bags
I going to put airbags on the truck now deciding which one Firestone Ride Rite, Load Lifter 5000, or Helwig they are all about the same price is one any better than the others? They are all 5000# but ...
Cummins12V98 wrote:Colo Native wrote:Cummins12V98 wrote:
The RV in your sig has about 12,350# GVWR with 20% pin weight you are at 2,470#. Does your truck sit level or is the rear lower than the front loaded?
The pin when weighed was 2360# it has about a 3" drop but it is level when not hooked up
I I understand you correctly your rear is 3" lower than the front with RV attached? If so potential buyers this is a perfect example of why you should opt for the 350 if choosing Ford.
