I going to put airbags on the truck now deciding which one Firestone Ride Rite, Load Lifter 5000, or Helwig they are all about the same price is one any better than the others? They are all 5000# but ...
If you're just looking to level your load, The Firestone airbags will do that for you and it's a fairly easy install...probably wouldn't take much air added to level the load.. When empty, you can probably drop air pressure in bags to minimum recommended.....just something you'd have to play around with when not towing:)
