dockmasterdave
Aug 20, 2019Explorer
I've had air shocks in the past and will probably be adding another set soon.
They are easy to adjust pressure up or down. If the pressure is low it will ride just like before, pump the pressure up and the rear goes up and stiffens a little.
Still not a horrible ride when pumped up.
A LOT cheaper than air bags and I'm not looking to add 1000 lbs of payload, just level out the truck.
Nothing you do to your truck will legally change it's rated payload, but it can make it more comfortable and ride level.
