jstaffon
Aug 20, 2019Explorer
Turtle n Peeps wrote:
Ok, here is MHO.
But, I have no idea what you mean by "movement?" Ya you're going to feel movement. You have a heavy 35' 5er in back of you. You're going to feel movement.
If I were you I would start by put a set of Bilstein shocks on. Chevy OEM shocks are junk right out of the factory IMHO. Start with that and see how the ride is.
If your truck is sagging then I would put a set of bags on it.
Can you describe what you're feeling or what you want your truck to do better?
The movement is minor. In an attempt to characterize the movement...I guess I feel tugging on the truck when going over dips in the road and some slight side to side pulling in cross-wind towing. To be honest, I may be too picky because the ride is quite comfortable. I'm trying to tweak it a bit. I thought maybe the movement I'm feeling is a result of weak shocks.
