flathead92
Aug 22, 2022Explorer
air compressors
what brand/type of small air compressors does anyone have, I seen a vid this youngster had this very small portable one and was pumping up TT tires. 80psi???
Lwiddis wrote:
Ryobi, battery powered and I recharge while driving with the 1500’s 120 volt plugs.
klutchdust wrote:
I have plenty of room under the bed in my work and play toyhauler. I carry some air line and can air up anything I care too plus I use it to blow out the dust etc. when on desert trips. The compressors that plug into a power outlet, in my opinion, are useless. If you needed to plug a tire and inflate it to get you out of a bad situation, they will take all day.
Neighbor drops this off one day saying he can't get the leak to stop, I could have it. (brand new) replaced the drain **** in the bottom, bingo. Funny my comment was bleeped out. It's what they are called/ labeled at the hardware store. :R
