hohenwald48
Aug 02, 2015Explorer
budwich wrote:
The "head pressure" is dependent on ambient air temps along with "run cycle" so depending on what outside temp was and how long you monitored it (ie. number of cycles), you may not have reached its highest "demand". The "starting capacitor" is used to limited the high current draw during startup.
I probably looked a 20 or so cycles. I let it run with fan in "always on" mode for 2 hours and then in "fan cycle" mode for another hour. Like I said, outside temp was in high 90's and inside thermostat setting at 70. Generator and TT were in full sun. Probably not worst case but pretty near what you'd expect on a 98 degree summer day in a WalMart parking lot.
