ksg5000
Sep 05, 2018Explorer II
Almost all the cut outs for Air Conditioners are the same dimension and the gaskets are sized appropriately. I doubt there is any meaningful difference between gaskets so don't waste time researching. When replacing just make sure you clean things up first - pressure keeps the gasket sealed - don't use caulk.
Edit. If your going through the trouble of replacing the gasket make sure you clean the condenser and evaporator coils. Most regularly clean the condenser coil but few clean the evaporator coil which requires removing lots of screws and a metal shroud. It's the evaporator coil and a clogged drain pan underneath it that creates many of the AC problems posted on this forum. You should make sure your "leak" issue isn't something as simple as a plugged drain pan b4 you replace the gasket.
44,068 PostsLatest Activity: Jun 17, 2026
