Triker33
Jun 15, 2016Explorer
1) has anyone had an RV a/c unit serviced and what was the cost? I have rinsed mine out. I believe its low on Freon or possibly even motor not running proper rpms.
What is the difference between the intake temp and output temp? Normal is 18-20º
Compressor not running? May only need a start capacitor.
Fan either runs or not. If not then it may need a capacitor.
2) the units come filled and ready to run as they are a sealed unit from what I was told--does anyone know if that's correct?
Yes
3) is swapping from the 13500 unit to the 15000 unit a direct swap?
Yes If it is a Coleman get a PS model.
4) any reason not to go with the bigger unit?
NO If you camp in cold/cool weather a 15K heat pump would be my choice.
Yes
