colliehauler
Jun 15, 2016Explorer III
duck1973 wrote:Welcome to the forum neighbors.
I have a 2007 Dutchman travel trailer. The trailer is 30' and came with a 13,500btu unit.
Called to have it serviced and the RV dealer said would be more expensive to have it serviced than replace it. He also said the 13500btu unit was to small for the camper. He wants to replace with a 15,000btu unit. Priced it at $600 and 150-$225 labor.
1) has anyone had an RV a/c unit serviced and what was the cost? I have rinsed mine out. I believe its low on Freon or possibly even motor not running proper rpms.
2) the units come filled and ready to run as they are a sealed unit from what I was told--does anyone know if that's correct?
3) is swapping from the 13500 unit to the 15000 unit a direct swap?
4) any reason not to go with the bigger unit?
1) Waste of money getting the old unit serviced. Throwing away money on service.
2) Sealed unit you were told correctly.
3) Should be a direct swap and a big improvement.
Discount RV has the best price around in Hutchinson.
