ksg5000
Jun 15, 2016Explorer II
Here's a link which will explain how your AC works and how to maintain it.
http://bryantrv.com/roofac2.html. You need to clean the filters, clean both the condenser and evaporator coils, make sure the fan blades are clean and there are no mud dobber nest etc interfering with operation, and oil the motor if there is a lubrication port. You should also inspect the capacitors - if they are bulging/leaking they should be replaced.
Maintenance of your AC is pretty simple stuff - easy DIY.
