tinacap's avatar
tinacap
Air Conditioner issues
With my pop up parked in my driveway, I was testing the A/C and had hooked up the cord attached to the popup to a 30 amp converter and plugged my extension cord in to it and the other end, in to my garage electricity.
I turned on the fan and it worked but when I turned the other dial to cool, the whole unit stopped working. I have checked fuses and switched them out. The only one that looked like it might have been bad was in the tongue (but I don't understand if that would have anything to do with problem). After replacing fuses, it still does not work. The lights work in the pop up.
Does anyone have any thoughts on this?
Thank you in advance.
  • I've run mine on 15 amp power before without a problem but, it's ALL that is on. The longer the run the bigger cord you need. You should have an adapter to plug your shore cord into that will then plug into a standard 120V household outlet. If you need you can then add an extension cord between the plug and outlet.
    All the Best,
    D. White
    All the Best,
    D. White
    Thank you everyone! I followed your advise and it works now!
