ckwizard777
Jun 18, 2014Explorer
20amp may not be enough power to run your ac depending on how long your cord is.
Also pull the shroud off the ac and check it out because you may have mud daubers in the fan preventing it from spinning.
Also make sure your hot water heater is on propane and Not electric if you have 30amp service because it may not be enough power for both.
44,056 PostsLatest Activity: May 04, 2014
