A/C unit is self supporting
Roof gasket needs to be compressed by 1/2 of thickness but not overtightened.
Tighten mounting bolts by hand then SNUG them up using a wrench.....'X' pattern
SNUG.......
40 INCH POUNDS if you have an INCH torque wrench (NOT FOOT POUNDS)
Otherwise SNUG. Which is just a little resistance when turning with wrench
If you overtighten ---gasket can get crushed, evap coil drip pan drain holes can get blocked (too close to roof) and then condensate will run inside rig and/or roof could wrap causing leaks from rain etc.
SNUG!
