Reddog1 wrote:
noteven wrote:
Off topic questions: Will a single Honda 2000i generator start and run the air conditioner the OP is installing?
It should run the A/C, but not the heat strip.
From the Spec sheet. Cooling the compressor requires 8.9 amps, and the high I.D. motor (fan) is 1.2. A total (maximum) of 10.1 amps. The specs say O.D. motor is 1.6. I don't know what the O.D. motor is.
The Honda 2000 output is 13.3 amps, from the spec sheet. So, that leaves you with about 3.2 amps to spare.
I have a Polar Cub which requires a maximum of 9 amps. The Honda runs the Cub just fine. I run the Honda in the Eco mode.
Wayne
Thanks Wayne - a Polar Cub would very likely be enough in my Snowbird 810 - I don't use it in temps much above 90F...at 3500 - 5000 ft
