elm3420
Jul 10, 2017Explorer II
air condtioner/thermostat isue
The thermostat in my camper isn't working right. You have to turn the temperature to 85 to get the air to come on. Then after it runs for a while and it is clearly cooler than 85 you have to turn down the thermostat down just a little and then it turns off. I believe that the thermostat needs to be replaced. But the other thing that is happening is that sometimes after the air is running for a while it pops the breaker. Is this being caused by the thermostat issue or is there a separate issue with the air conditioner? Thank you in advance for any help that you can give me.
