GoinThisAway
Apr 18, 2015Explorer
I've been interested in adding one to my TC but it is fiberglass with no pre-existing screws to use for attachment. Has anyone installed one on a Bigfoot, Northern Lite, or other fiberglass TC? I've wondered if the 3M or similar tape that some use to attach solar panel brackets on the roof of such campers would work for this. Would there be problems with fatigue failure of the fiberglass with constant flexing of the air dam as the load on it changes due to changing speeds? I'd think an air dam with its surface perpendicular to the air flow by design would have a higher load and a higher load range than a solar panel that is mounted with only a narrow edge perpendicular to the air flow.
44,071 PostsLatest Activity: Aug 30, 2026
