HMS_Beagle
Jul 26, 2016Explorer II
Air ride!
I just installed an airbag suspension on my new '15 F350 dually and took it on the first camper trip. I will put at the end of this post the reasons for doing it to save the long narrative for those i...
HMS Beagle wrote:As far as the multi-link suspension, whether it be a coil sprung or air sprung system, multi-links have been used on the front ends of cars, pickups, vans, suv's for many years.travelnutz wrote:Actually it will just come down on the bump stops, better than breaking a spring which will lose control of the axle.
Only major issue I see with cantilever air ride systems and removing the OEM springs (while there's many good points) is in a bag etc quick failure, there's no backup support system at all and it can have very catastrophic results for control loss.
I suspect more of the reason we don't see these on pickups is it costs more (because you need a control system and air source) and it requires a little more knowledge in care and maintenance. Air ride is becoming quite common in passenger cars and SUVs.
