- CharlesinGAExplorer
KD4UPL wrote:
I wouldn't use air shocks for anything. Shock mounts are NOT made to support weight.
If I put shocks on a trailer I'd put them on both axles.
I hope this is what you intended to say. Shock mounts take a lot of stress, but are not designed to carry any real weight.
OP should consider a set of the equalizer replacements that have cushioning or dampening in them, Dexter E-Z Flex, Lippert Equa-Flex or Road Armor, or MORryde.
Charles - Yosemite_Sam1Explorer
CavemanCharlie wrote:
I think we need to know first why you are putting air shocks on ? Are they just for the dampening action or are you trying to solve some sort of problem you are having ?
To prevent those stuff inside the RV from flying all over.
Good enough reason to spend $600? - stickdogExplorerWe had a Centerpoint air suspension made for a smoothride didn't add anything to CC.
- Grit_dogNavigator II^ Too much electormagnetism to the brain from driving those Duracell powered cars around has caused some irrrrep...errrap...irreparable damage I fear!
The better question is does the Cybertruck come with air shocks and will the trailer need then as well if being pulled by cybertruck?
Or will you need a 6kw generator to recharge the truck, hence the need for air shocks for the additional payload of the generator? - KD4UPLExplorer III wouldn't use air shocks for anything. Shock mounts are made to support weight.
If I put shocks on a trailer I'd put them on both axles. - TurnThePageExplorerREGULAR shocks are great for damping motion. Shocks are not meant to support a load.
Back in the 70s we used air shocks to jack up the back of our wanna be hot rods. - CavemanCharlieExplorer IIII think we need to know first why you are putting air shocks on ? Are they just for the dampening action or are you trying to solve some sort of problem you are having ?
- Yosemite_Sam1ExplorerLOL, why indeed!
And why make the extra expenses. Or a solution in search of a problem. - drsteveExplorerWhy would you want one axle to respond differently than the other?
- Turtle_n_PeepsExplorer
carringb wrote:
Why would you put air shocks on a tandem-axle trailer? If the springs are sagging, fix those!
LOL. ^^^^^^This!!
