Vinsil's avatar
Vinsil
airbag question
Got my bags on today. Got my tire pressure dialed in for daily driving, running the 285/70/19.5 Michelin XDS 2's at 85 psi, they run smooth. Haven't loaded up my TC yet, but I figure they will be taken up to 110 psi and see how it goes. They are rared for 120 psi, but I won't be loading them to max (thank god) of 6395 a tire.
So, put the bags on, manufacturer recommended 30 psi and run for 10 miles for a break in and test for any issues.
Truck rode fine, did not really notice them much. What do you guys run for daily non-loaded pressure?
What about loaded? I figured I would just level it but open to hear how do you run yours.
FYI, I also run lower stabloads as well. Thanks all, truck has come a long way. Unfortunately I might have to add in a leveling kit, getting some minor rubbing that annoys me.
  • The MFG list a minimum pressure to run your airbags unloaded to avoid pinches. as far as loaded. just enough pressure to level the bed and not enough to disengage the upper stable loads if you have them.
