Grit_dog
May 06, 2018Trailblazer
IdaD wrote:
etrailer has a coil sumo spring that looks like it would fit. Not air but maybe the same result. I've never used one and hadn't ever seen anything designed quite like it but you could check it out.
Well, this was the only real answer to the OPs question after 2 plus pages of "if you look on p173 line 17 it CLERLY states to adjust the Fluux capacitor to 77.3% of minimum magnetoidal influence during the summer solstice at exactly 1:33pm....."
Looks like sumos are about the only available option at this point. But I wonder, with the height and diameter of the coils, you may be able to match up some front axle coil spring assist bags that go inside the springs. More disassembly required, but adjustable.
