blaczero's avatar
blaczero
Airbags and Compressor and Tank
I am looking for a way (I cannot be the first person) to have a compressor that airs up my airbags and also has a port to plug a hose into for airing up my tires.
I get the concept of having a nice compressor and tank attached to my frame, but what controller would I put in between the tank and the bags?
  • There are pneumatic control panels if you have the air source available (ie your onboard air system), for about $200 Firestone makes them. If you want in cab airbag control.
    That's about the simplest and cheapest unless you pieced one together.
  • Lwiddis wrote:
    First item to fail on an air bag system is the pump. I use a bicycle pump. Easy, quick, replaceable.
    That was helpful....
  • Anything goes as far as a valve and gauges. I ran a tube from the tank to the back of the truck so I can connect a hose for tires. Craig
  • 2112's avatar
    2112
    Explorer II
    This Guy did a real clean install on his TC. Maybe you can get some ideas from this. I like how he located his air intake and hose QD in the cab.
  • There are onboard air systems for exactly what you're wanting to do.
    Example
  • First item to fail on an air bag system is the pump. I use a bicycle pump. Easy, quick, replaceable.
