thejustin wrote:
Does anyone out there run the uppers lowers and airbags at the same time and have any experiences with the ride quality?
I run run airbags
and extended upper and lower overload bump stops that are nearly identical to upper/lower StableLoads This combination offers great ride quality and allows me to keep the pressure in the airbags to 25-30psi or less. Of course my truck is a RAM so YMMV.
Note that you should run your airbags at as low the minimum pressure that will restore your desired ride height. High airbag pressure causes a harsh ride due to them having a rapidly rising spring rate.
Cheers
-Mark
