sky_free wrote:
I have the exact same truck that you have, with both upper and lower stable loads and Rancho 9000's. I added uppers first and they did nothing to raise the back end, but did eliminate some sway. Then I added the lowers and it lifted the back a little over an inch, so now I have about 1 1/2" of squat with no water on board. With full tanks and loaded to go, I'm back to about 2". This is pretty good, but I am interested to see how the bags work out for you because ideally I would like some adjustability.
As far as the stableloads damaging the lower overload, I can't see it happening on our trucks. That spring is incredibly thick and tough. I think the stable loads would get destroyed before the spring. They seem to be made of softer steel. Time will tell. Springs are not that expensive, so it's a cheap fix some day in the future if necessary.
I added Rancho 9000's last. The stock shocks had 46,000 miles on them and it was not ideal. I set the back's at 9 and the fronts at 6 and the ride is much more stable. When road condition cause the load to sway, it now recovers with one move instead of wobbling. Don't know if they will last based on some reports from others, but I'm happy with them now. All the shocks I researched had reports of failure, so it's hard to know if these are more or less reliable than the other choices.
Please let us know how it works out with the air bags.
I put my upper stableloads on almost immediately after I got my first TC. Brought the rear end up maybe an inch or so. I would be ecstatic if I could get 1.5-2" of sag reduction just from the lowers. I just don't know if its going to be worth the cost. I know I can get them for 180 shipped from Amazon, but I would like to have them dealer installed. I know people will say its an easy install, but I know can't do anything worthwhile with hand tools and do not trust myself tinkering around with the rear suspension of my tow vehicle. Would rather just pay for professional install and have peace of mind while I'm driving through the mountains and not worrying about my rear end falling off.
Anyway, only place in town that has the lowers in stock is the dealer who is doing my bag install and they are priced at 242.00 at the shop (!). My airbag installation is being squeezed in on Tuesday and all the RV shops here are booked solid well through June, so if I don't get the lowers and have them installed on Tuesday with the airbags I'd be waiting for July to get them put on (this also rules out me buying them from Amazon and bringing them into the shop since I need to have them delivered by Tuesday and the free shipping from Amazon to Alaska is sent Parcel Pool which takes about 2 weeks from date of order).
Kind of leaning towards just skipping the lower stableloads and just using the Firestone airbags in conjunction with the existing upper stableloads that are one there. I was thinking about it last night and I gather the point of these is to preload the overloads because in many instances they won't even engage with a load in the bed, but I am just about at my max payload hovering around 4500-5000 lbs. in the truck bed. Shouldn't that be enough weight to sufficiently engage the overloads? Are the stabeloads even necessary with a weight that large?
In terms of return on cost, I would be paying 242 + ~100 bucks or so in labor for install on the lowers........ Rancho is having their summer sale and I can get a 100.00 rebate and order a set of 4 9000xl's for about 300 bucks. I think the shocks would be a more apparent upgrade in ride quality than the lowers for the price, still hoping someone on here has a 350 with the uppers, lowers and airbags and can chime in on the ride.
