Basically there is sand and there is sand. The best tire pressure varies with the consistency of the sand. In dune blow sand I'm down to 22 psi-front, and 20 rear. But that's deceiving too. I use 15" wide super single rear tires and can run at a lower pressure and have a terrific floatational factor with no deleterious effect. Here is the sidewall deflection at these pressures: Before deflating on blow sand: sorry, it's fuzzy, but the only one I have, stuck.
After dropping to the pressures listed above:
On sand that's more packed, I go down to 28 psi-front, and 24 psl-rear. On sandy roads, I'll drop to 30/26. This last pressure set is the 'go-to' pressure for long, boondocking, sandy road, southwest locales. This was my pressure on the White Rim Trail and the San Juan High excursions.
regards, as always, jefe
