ohpoppy's avatar
ohpoppy
Airstream Caravel towing mpg question
I just bought a 17' airstream in OK city and drove it home to SC. I got 13 mpg leaving Okc (2005 Volvo V70 tow veh)which is very poor but as I continued on mpg improved dramatically, gradually. When I reached SC. I was getting 21 mpg. Altitude?? or something else caused the difference. I wonder if it took 1000 miles for the cpu to re-calibrate the best fuel mixture for towing 2500 lbs and it took 1000 miles to do it. Has anyone noticed the tow vehicle getting improved performance after driving a while in the same altitude? I wonder if disconnecting the battery before towing will cause the cpu to immediately re-calibrate or faster then just hooking up and going. maybe its just altitude! car gets 31 mpg not towing on hwy.
  • it is a 67.. as far as being realistic about mpg, it got 21 as I wrote. that was on I-85 heading north from Montgomery AL to Anderson, SC my home. yes that is good mpg. if it is due to engine calibration I would like a remedy to start right off getting the 21. anyone know about such things about speeding up the calibration process if that is the reason?? its more then just about money, it drove better at 21. at 13 it was straining and it was hard to reach 65 mph. at 21 I could cruise at 70.
  • The Caravel is a small trailer that has pretty good aerodynamics and that weighs very little. (What is it? About a 1967 model?) No shock to get decent mileage. OKC is hardly at elevation, so that doesn't seem like a likely story to explain the change in mileage. I suspect that the self-recalibrating system of your Volvo might explain it.
    Lynn
  • If you were getting 13 mpg you were doing pretty good. Anything above 15 is highly unlikely unless it was all downhill, a big hill.
    Reportedly most towing an Airstream do get somewhat better fuel mileage than those of us towing conventional travel trailers but 21 mpg ??? You must be kidding, I know of no one that gets that kind of mileage towing anything. :E Typically most towing an Airstrem might see something like 14 mpg while 10 mpg to perhaps 12 mpg is typical for the rest of us. You're just not being realistic expecting such extreme fuel mileage returns.
