Then you can't have seen the Lippert frames that have fabricated I-beams made from 3 separate pieces of 1/8" mild steel welded together that *look* like a regular I-beam. They are extremely flexible and result in all sorts of major issues including fatigue cracks above the spring hangers. These frames are so flexible, the aluminum framing in the superstructure can even be damaged. These frames are used on 5-6 makes and models of ultra-lites that I've seen. VERY poor design and there WILL eventually be issues if you keep it long enough.
Even "regular" cast steel frames can have issues. Just google "travel trailer or fifth wheel frame cracks."
Lippert went through certification for their welders? You'd never know looking at recently produced frames. I've even had the good fortune (haha) to have a government certified frame and axle shop inspect a 2013 Lippert frame and they said it had serious flaws and was a really poor design. They said the welding quality was poor and not done to typical standards & practices. Very enlightening experience.
Lippert typically blames the owner for any problems and tells you that it's your fault because you overloaded the frame or they may say it's normal. It's very difficult to get them to accept liability and have experienced that first-hand and had to work extremely hard to change that.
A BIG problem in the TT frame industry is that there are NO regulations that a frame manufacturer has to comply with. They can, and do, build whatever they want without accountability to anyone. We've had serious problems with a Lippert frame in the past and I am flabbergasted at what was found wrong.
Thus concludes my thoughts on Lippert frames.
If you want to get a good frame, buy a TT with a BAL/Norco Ultraframe or buy a Nash or Outdoors RV TT that use their own in-house built frames that are independently certified or buy an Airstream.
mileshuff wrote:
Lippert doesn't make frames for Airstream. I'm not too worried about Lippert frames anyways. They had some issues several years ago but haven't heard much trouble in quite some time. They went thru a lengthy training and certification for all of their welders which was certainly a good thing.
I do believe the Lippert frame issues were somewhat exaggerated. Lippert has more frames on the road than any other manufacture by a wide margin. So they will have a higher # of problems showing up. I haven't had any frame issues myself but did have some minor brake/axle issues. Lippert was 1st rate in resolving those issues.
