When looking for a trailer, everything is a trade-off and compromise. If you are planning on staying in campgrounds with full hook-ups, the Airstream might be a good choice. If you plan on boondocking, the Airstream might not be your best choice. The AS Sport 22 has a limited NCC of 866 lbs. and limited tankage (fresh: 20gal., grey: 24 gal., black: 18 gal.). These limits might be a deal breaker for boondocking. Compare the Airstream specs with the Lance specs and you will see that that Lance has substantially larger NCC and tankage, ideal for boondocking.
