69 Avion wrote:
westend wrote:
Hi 69 Avion,
How difficult a job is it to put new flooring in an Airstream? Can you unfasten the top shell, elevate it, and put in new plywood? I would imagine that there are some plumbing and wiring concerns along the way.
I have my eye on a 50's single axle Airstream that will need a total rebuild. It's a cute little rig, good for a couple weekending and will probably pull easy.
Maybe sticking a whole new platform with running gear ala' your C-11 would be a better solution. I can only imagine the state of the axle after sitting for 20 years, although I did rescue a boat trailer that was sunk into a swamp a couple of years ago.
I have never done it myself, but the AirForum shows several folks who have. It requires lifting the entire shell off of the frame, replacing the floor and then putting the shell back on. When the shell is off it is a good time to fix any frame issues, replace the axle, repaint with POR and do all the work you can do while the shell is off. If you seal the plywood, with epoxy, it will be much better than new when you are done.
Don't worry about replacing the axle, they are cheap. Besides, you want new brakes and by the time you buy new brakes, bearings, seals, etc, it is cheaper to buy a new axle and springs and be done with it.
Thanks! Ill look over the situation with the Airstream before I go forward.
