ROBERTSUNRUS
Feb 18, 2016Explorer
reddwar wrote:
Wife broke her leg & has a hard timing climbing up into our 5er. The airstream is a lot lower + she does not have to clime once inside. Looking at getting 26-27' 5-10 years old. I have seen some folks have had water problems & they use pressure test to check for leaks. Is it just some years have they fixed it or what? So if I find one I like do I need to do a pressure check?
Red
:) Hi, do you need to do a pressure check? No, but it's not a bad idea. Very easy to see if the sealants on the roof are in need of replacement. Airstream does use a pan under the roof air conditioner because of the curved roof and because Airstream runs a drain tube for the air conditioner through the walls and mine drains out, in a wheel well.
