Anonymous
Dec 10, 2015donn0128 wrote:
Check the volume rating at 40 PSI. Most of the 12 volt jobbies are in the range of 1-2CFM. Which is basically useless.
Useless? I have a Harbor Freight unit that's rated at 1.35 CFM and it tops off my 34" tires on the truck rather quickly. Filling up flat trailer tires only takes a few minutes. I wouldn't have one issue with using it on the side of the road in an emergency situation.
OP: The Airtight unit appears to be poorly crafted according to Amazon reviews. I would look at units that have alligator clips vs the 12v socket connection. 12v socket versions normally have limited power and the clips give you the ability to use the compressor anywhere there's a battery. Harbor Freight has one that can be had for about $45 with a coupon.
Wilmar 60404 Amazon
Harbor Freight Compressor
44,066 PostsLatest Activity: May 16, 2026
